How do I call out tight parallelism but loose flatness on two surfaces?
I have a part roughly 3" x 5" with two parallel surfaces. The surfaces only need to be flat within .008" but parallel with each other within .0002". Can I apply a flatness tolerance of .008" to one surface and call it datum feature A, then apply a parallelism tolerance of .0002" to the other surface referencing it to datum feature A? My goal is to tightly control parallelism between the two surfaces but loosely control flatness.
Tom
Tom
RE: How do I call out tight parallelism but loose flatness on two surfaces?
Remember,variation in datum reference does not affect the parallelism tolerance value.It can as small as design requirements allow u.Datum feature A flatness will be be controlled in 0.008 of an inche and parallelism of considered feature will vary within .0002 of inch but remember one thing as well.For Planar feature whenever an orientation tolerance is applied then it controls its flatness also.So flatness of considered feature is limited to 0.0002 on an inch UNLESS U SPECIFY FLATNESS WHICH MUST BE LESS THAN 0.0002
Here is a pic of my drawing:
Tom
Orientation
Form
Parallelism is not a workable concept for what you are doing. Parallelism is measured with respect to a datum that is determined by picking up two or three points of your reference surface. Your reference surface is allowed to be very sloppy, even with a tight parallelism tolerance.
I think you are going to need a note on your drawing.
JHG
