Rapid Surfacing Attachment = None
I'm using NX6 and using the rapid surfacing tool.
I'm trying to optimise the results I get from the tool by tinkering with the options understand the tool a little better, however, I'm baffled about the effect of setting 'None' in the attachment option. By default it is usually 'Facet Body', so what is the purpose of having the None option?
Cheers
RE: Rapid Surfacing Attachment = None
Have you read the user documentation for the Rapid Surfacing function? If not, simply open the dialog and press the 'F1' key and you'll find the explanation of what the 'Attachment' option (and it has nothing to do with the facet body).
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
