FM / CSA Coaxial cable
Our company provides equipment with armooured coaxial cables (RG62 A/U). We have a requirement to supply our equipment into a hazardous area, that is not ATEX but FM/CSA certified.
We can procure CSA certified armoured cable glands, but im not sure if its possible for procure FM/CSA cable?
Can someone help please?
RE: FM / CSA Coaxial cable
http://www.fmglobal.com/page.aspx?id=03050000
This is like as UL Approval for a certain product. So, "UL approved" it is the same as "FM approved".
Usually a cable could be produce following CSA and UL Standards so it will be equivalent.
See [for instance]:
http://www.belden.com/techdatas/metric/82262.pdf
If you intend to purchase this cable certified by CSA you may ask the manufacturer [Canadian] if a FM label could be tacked on the product. See[for instance]:
http://www.electrocables.com/about.html
