varying thickness of RAFT slabs
Hi All...
I have a raft under a building that is 1200mm.. and also a portion of th ebuilding where the raft os 750mm thick.
How should i joing the raft with varying thickness.. shoudl i taper the 1200mm raft to 750 gradually.. or is it ok to have sudden drop from 122-750?
I have cheacked , and there is no stress concentratio n near the edges.
any standard details in ACI?
