how to create a vacuum between two layers?
I've got two machined parts and pcb. I have recess in my part which allows the sensor on the board to fit inside. The sensor measures the pressure of whatever our customer wants to measure. So because of this I need to create a vacuum between the contact surfaces of board and machined nozzle (hardened steel). Hence need some sort of lubricant or something to achieve this. I have heard about vacuum grease, but not sure if it will cause any problems on the board's components. Any experiences? And what is the difference between high and low ones? my guess is probably a tiny bit less volatile and not long lasting? or is there anything else?
Does anyone know of anything else better? Thanks for you help!
Cheers,
V.
Cheers,
V.
RE: how to create a vacuum between two layers?
Is it cost effective to make the part serviceable? Meaning, why not use a permanent adhesive? Or just silicone sealant (caulk) which isn't permanent if you really don't want it to be.
TTFN
http://www.hylomar.com/index.php?option=com_conten...
or
http://www.dowcorning.com/content/news/iam_news32....
TTFN
