B31.1 Overpressure protection requirements
Hi all,
I have to design a system with 500psi design pressure and need some help on overpressure protection requirements.
Is there any compiled document which I can refer which provides all the requirements of B31.1 for overpressure protection.
Going through the code, I found information all over the place and that has become a bit confusing.
Any guidance will help a lot.
RE: B31.1 Overpressure protection requirements
Basically what are B31.1 requirements of overpressure protection.
sect 122 provides guidelines for specific piping systems, such as main steam lines, etc. Par 122.8.1.d defines the required system design for combustible gas systems with no relief valves.
107.8 specifies releif valve sizing as per asme sect VIII div 1 requirements
"Nobody expects the Spanish Inquisition! "
