Can an MSFlexGrid be used with DAO?
I'm using VB6 with MS Access 97. I have a multi user environment and need to keep my connecting time to Access to a minimum. How can I populate an MS Flex Grid using DAO. This will enable me to cut the link when the grid is populated. Alternatively is there a way to cut the Data Control link dynamically once the grid is populated?
JonH.
