Can you MIRROR objects in Visio 2007?
I'm pulling in the FUSE from the Electrical Engineering Switches and Relays Shapes.....for what I'm doing the fuse needs to be drawn with the fuse portion on the right and the disconnect on the left, exactly the mirrored opposite of how the item is drawn. Seems you can rotate, but is there a way to MIRROR?
RE: Can you MIRROR objects in Visio 2007?
TTFN
These are the kind of questions I would normally bug my co-worker for. But I don't have a co-worker, so thanks again!
