0.6 Dead + 1.0 Wind Load Combination
Looking to see what others do for this situation. For the 0.6D + 1.0W ASD load combination, do you use 0.6 of full design dead load allowance, or do you use 0.6 of absolute minimum actual dead load? This isn't an overturning thing, it's a net uplift on roof thing.
RE: 0.6 Dead + 1.0 Wind Load Combination
I don't think the code is particularly clear on it. Personally, I try and use as realistic estimate of dead load as I can.
The 10% overestimate argument does make sense to me though. 0.9 / 1.5 SF = 0.6. It's my understanding that the 1.5 safety factor is implied for overturning with the equation. Makes sense to me to extend this to uplift as well.
You don't get the reduction in overturning when checking soil bearing with this combo, but I think it yields a more realistic soil distribution if your design DL are not over done.
If you're working toward stability and using the footing weight for a resisting moment, I feel the 0.6D is too conservative for the self weight of the concrete even when thinking about vertical accelerations in combination with lateral accelerations.
Brian C Potter, PE
Simple Supports - The history and practice of structural engineering.
ConstructionPic - Send annotated jobsite photos.
