Spline to polyline not working
Hi, I am trying to import some geometry into DraftSight. The geometry started as an SVG, I converted it to a DWG in CorelDraw and it opens fine in DraftSight. But the lines open as Splines. I understand from the help files and tutorials that I should be able to just select the spline, do a PEDIT and it wil convert to a polyline - but it doesn't - everytime i click on the spline I just get the message "Specify Polyline". I have also tried creating a spline from scratch and trying the conversion or creating a polyline and trying to "JOIN" the spline to it - no dice. I just cannot seem to convert the splines to polylines. Am I missing something?
Best James
Best James
RE: Spline to polyline not working
Hope this helps. Diego
POLYLINE and SPLINE are two different entities in DraftSight. You can edit or convert polyline to spline (command PEDIT - Spline, or Fit), but still it is polyline. Spline can not be converted. You can edit it only drag data points, or fit tolerance. You're probably quite understood the description in Help.
