Fix problem with occasional broken links?
Hi Guys,
I keep coming up against a problem whereby when I send a product with the associated parts to another user, that on occasion the data will exhibit broken links even though the part file is there and loads absolutely fine on my machine (with a cleared cache or not).
Is the 'Reconciliation' Command something I need to run on the products before sending them to check that all the links are ok?
I have tried CATDUAing everything, with no success.
Thoughts?
RE: Fix problem with occasional broken links?
The search orders are correct.
So my machine points at Folder A, their machine points at Folder B, and the data from Folder A has been copied into Folder B, with no corruption.
