Allowable stress for non standard material (ASME section 8 Div-2)
How to arrive allowable stress per ASME Section 8 div-2 based on yield strength and ultimate stress. what is the code reference.
I wanted to use the modified material (by quenching and Hardening),the UTS&YST modified to 105ksi&85ksi , what are the code reference for this??? how much allowable can be considered???
RE: Allowable stress for non standard material (ASME section 8 Div-2)
material is listed in asme ,but i m modifying the UTS and yield value ,in this what is the recommended procedure or relation to arrive allowable stress(S)??
my vessel is not certifying to ASME.
I would ensure that the values of yield and ultimate are uniform and isotropic. The procedures for calculating S are contained in ASME Section II, Part D, Appendix 10.
