UG NX6 - Issue when adding or removing items from a Reference Set
Hello All,
I've recently tun into a problem. I'm not sure if I caused it, or an update caused this. When trying to add or remove items from a MODEL reference set, it just closes the "Reference Set" menu, and doesn't add or remove what I am selecting. Also, why is the "add components automatically" button greyed out so I cannot select it? Are there "Reference Set" preferences stashed somewhere that I keep overlooking, such as in the Customer Defaults menus?
This doesn't work:
FORMAT --> REFERENCE SETS, highlight MODEL reference set, then add or remove item.
Thank you in advance...
This doesn't work:
RE: UG NX6 - Issue when adding or removing items from a Reference Set
When removing something from that reference set hold your SHIFT key down, and select it. It should work.
Why is it greyed out ? because that's the way it is, I guess.
Have you tried creating a differnt reference set and utilizing that instead of the MODEL reference set ?
Yes, I tried creating a different reference set. It closes the reference set window.
I get the same problem, especially when I don't sign off my computer each night.
I never really had the problem until we went to WINDOWS 7.
NX 6.0.5.3 (NX 8.5 Testing)
Windows 7 64
