DC Power bus stability
I'm searching actually a software which alllow me to perform simulation to check the stability of a DC power bus.
I know that we can use the Middleborough criteria to define the stability of a DC power bus. But when we have more than 10 converters on the same power bus, it seems hard to check.
Yes, of course, i can do it manually, but i don't want the result in 2 months.
Nota :
power bus : 28V and 100V, between 1kW and 30kW.
RE: DC Power bus stability
Small encore: Inquire at
http://www.hvdc.ca
for dc analysis software. They used to have one in the past. They may now use it for their own consulting services, which is the normal trend on the internet.
