ST5 '' The material table file is not available for write access''
When i want to add material to library, the popup ''The material table file is not available for write access''.
Any body know wath's i'm going to be?ponder
RE: ST5 '' The material table file is not available for write access''
Security settings on the folder or file in which the material file exists.
Someone either set the material file to read only, or it was placed on a network drive that does not have write access. There have been strange sporadic issues of Windows user-access settings (running as a non-administrator) not being able to write to the default file location. That's one of the reasons why ST6 changed the default installation location of settings files.
--Scott
www.wertel.pro
