High pressure poly
High pressure poly
Is anyone aware of a poly pipe product that is suitable for approx. 26 barg design pressure in 24" (natural gas service)? It's off the charts for the usual products, but perhaps there is a more advanced product that I'm not aware of.
RE: High pressure poly
A lot of the fibre reinforced stuff goes up to 26 and beyond, but PE will just end up too thick.
The 20 barg product that LittleInch mentioned has that rating at 23 C in clean water. Any other product or higher temperatures drops that number quickly.
If you have a legitimate need for poly and for your pressure rating and for the pipe size, don't screw around with half solutions. Using SDR-7, you would need to go to a 36 inch nominal product in HDPE to get 24 inch ID.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
Independent events are seldomly independent.
David Simpson, PE
