motor enclosures and ho
could you tell me if the type of induction motor enclosure such as tefc or tewac is related to the hp?
at times i have seen the same hp in different enclosures, and the answer is "client preference" (easy) but is there a more technical reason which could justify a particular selection
thank you
thank you
RE: motor enclosures and ho
"Will work for (the memory of) salami"
