Screw Hole Threads
Screw Hole Threads
Screw Hole Threads
Hello All,
I'm very very new to solidworks. I have version 2013 Premium 64bit SP3. I'm in the process of going through some training using some videos I downloaded from the net. I draw very basic part currently with ACAD2014, rectangle parts mostly for machine products we manufacture. I was curious about SW so I started looking into it and now I like it. So here's my questions:
For practice only.
I created a part .88" wide by 1" high by 3.5" long.
I added a 3/8 NPT hole on the side of it. It did not show threads, only the hole size, type & depth. In ACAD I added some circle to the existing hole and then trimmed them to look like threads. Is there a way in SW to show threads? OR do I do the same as in ACAD?
Thanks in Advance
KenJG
RE: Screw Hole Threads
Did you select the Cosmetic Thread option when creating the hole?
Hello CorBlimeyLimey,
I did use the Cosmetic Thread, W/Thread Callout & Thread Class
Thank you for replying so soon. :)
KenJG
I'd Check Options > Document Properties > Detailing that "Shaded cosmetic threads" is checked
After that, check that View > "All Annotations" is selected.
Also make sure the Tools - Options - Document Properties - Detailing - cosmetic thread options are selected.
Hello All,
Thanks for the GREAT HELP. The problem was in the Options > Document Properties > Detailing that "Shaded cosmetic threads" was not checked.
Thanks A MILLION. I'll be back with more "Q's" once I move on to my next training videos.
See You All SOON !!!
BR
KenJG
