Design Table Values
Design Table Values
Design Table Values
Is it possible for assigned design table values to drive a component mate in an assembly? I would like to create a custom mating distance property in my component and have it 'distance-mated' from a specified plane.
SW Professional 2012
64 bit SP1.0
Intel Xeon X(R) CPU 1603 0 @ 2.80 GHz
8.0 GB of RAM
RE: Design Table Values
If that doesn't work you can establish a plane based based on a sketch, the dimensions of which are controlled by the table.
I do not see why a Design table in the assembly would not work for what you need. If you are trying to drive a components size within an assembly, you will have to in-context the part in the assembly.
I did something like this nearly 10 years ago using an Assembly Design table, planes, distance mates and In-Contexted parts. Just be sure you understand and know what you have already done if you start in-contexting parts. It can get very complex, very quickly.
Scott Baugh, CSWP pc2
Berry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
Nella95,
The distance value in a mate is a dimension. It is controllable from the design table. Double click on your mate and you should see it. It works the same as a sketch dimension.
JHG
