Power System Software - MS Access Database to Graphical
I have a couple of MS Access databases comprising of the locations poles, switches and equipment of some MV network. I want to use software to take the information in the database and analise the network graphically (maybe super impose the network on some maps using ArcGIS) Can you recommend any open source software to achieve this task?
Indy
Indy
RE: Power System Software - MS Access Database to Graphical
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
If so, you can add the data directly within ArcGIS by clicking on FILE > Add Data > Add XY Data. From there it will walk you through a wizard where you can browse to the database file and point out the X and Y coordinate fields.
