Uploading Problem
Uploading Problem
Okay, so this question is a bit of tricky one. Not sure if this is the best place to ask because it also has alot to do with computer but it's worth seeing if anyone knows the solution. We have a control right now for a CNC that we can plug in a USB to upload programs. The problem is though that the tech that came did not give us the software for it to be able to read a normally formatted USB. The machine can still only read floppy format. Is it possible to format a USB so that the control reads it as a floppy?
Thank you for any help!
Sam Slivinski
Using NX 6
Manufacturing/Aerospace
RE: Uploading Problem
Suggest you try sevenforums.com
I've seen a discussion there regarding such tricks.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
