MAGNETIC BEARING ISOLATORS
Hi All..
I have a question regarding magnetic bearing isolator for pumps, i hope anyone can help me on this,
1. in what application/what condition that pumps suggested to use magnetic bearing isolator?
2. I have read some project specification said that "pumps with steam-quench of the seal shall have magnetic bearing isolators", my question is, what is relation between steam-quench of seal with magnetic bearing isolators?
Thank you
Thank you
RE: MAGNETIC BEARING ISOLATORS
We have not had good luck with application of magnetic isolators in our plant. But, we were applying them to pumps with oil mist lubrication. There are particular requirements in oil mist applications to allow the oil mist to lubricate the magnetic isolator before the pump is started up. If you don not following these requirements, the magnetic isolator may burn up on start-up. This can be handled procedurally.
Johnny Pellin
