Threaded rod anchor to steel beam
I have a second floor shear wall supported by a steel W-BM. Need to anchor the ends of the wall for uplift. Using a holddown and threaded rod, but will need to connect the threaded rod directly to the top flange of the steel beam. I have found connectors that will weld to a steel member and connect to a rebar, but cannot find this same type of connector for a threaded rod. I did find one that had a threaded end to a rebar. Does anyone know of a good connector for this case? Thanks and have a great day.
RE: Threaded rod anchor to steel beam
http://studweldprod.com/studs/index.php
(I am not affiliated with studweld or any other product supplier)
What about drilling a hole in the flange of the WF, and using a couple washers and 3 or 4 nuts so you can lock the rod to the WF? What prevents the WF beam from lifting due to this upward force, if and when it occurs?
http://www.strongtie.com/products/connectors/cnw-h...
This is what we also typically do.
My technical language minding mentor notes them as "threaded stud bolts" on drawings.
Mike McCann
MMC Engineering
