building moving laterally under gravity loads
Hi guys,
When core walls location is eccentric and the building is displacing laterally under the gravity loads, is there any limitation to such kind of limitation ?
thank you
thank you
RE: building moving laterally under gravity loads
Mike McCann
MMC Engineering
Mike McCann
MMC Engineering
BA
Chekre....Have you considered that the heterogeneous nature of your model might be introducing errors?
Mike McCann
MMC Engineering
What you might do the eliminate this issue is a) include the construction sequence in the model or b) increase the axial stiffness of the columns in order to get the same vertical displacements in the walls and in the columns (beware of the side-effects associated to the change of the global lateral stiffness).
Hope it helps
