Steel Beam Flange Out of Square
I'm reviewing a three plate steel beam that was fabricated with one of the flanges not square to the web. It is a 12" wide flange and when I put a framing square against the web the tip of the flange is off by about 3/8" (3/8" across a 6" distance). If I remember correctly, the AISC tolerance for this is 1/4" There is nothing that bolts or attaches to this flange. I can calculate the section properties of the shape and I doubt there will be much difference than those from an intolerance shape. Other than that, are there any other concerns that I should check?
RE: Steel Beam Flange Out of Square
www.SlideRuleEra.net
www.VacuumTubeEra.net
