Setup for radiation pattern measurement
I'm trying to put in place a setup to measure radiation pattern of 2.4GHz antenna. Right now I've got a turntable controlled by a motion controller and a network analyzer (Agilent 8753ES) all controlled by a Labview VI that we wrote. The vi is turning the table, making an acquisition of S21 on the network analyzer and at the end, plot the result in a polar graph and save datas.
1) Do I need a reference dipole to characterize the environement of the setup (reflexion in the lab, calibration)? If yes, what would you recomend, what manufacturer?
2) What distance is recommended between the antenna under test and the antenna that illuminates it? I read that I need to be in the far-field region to do this measurement, which is given by R=(2*SQ(D)/lambda), where D is the max antenna dimension. As D=3cm (roughly, 1/4 wavelength antenna), this yields to R = 18cm2/12cm = 1.5cm. Is it really correct?? I'm right now at maybe 2 meters.
3) What calibration is required on the network analyzer: is the two port OK?
4) How do I go from my measurement to actual dBi? Is the reference dipole required for this?
5) How do I define the power level I need to "illuminate" the antenna under test?
6) Any website on the subject you could recommend?
Thanks a lot in advance.
Hugues
Hugues
RE: Setup for radiation pattern measurement
http://www.byte.com/documents/s=1422/byt20010926s0002/1001_marshall.html
IEEE 801.11b
http://www.alvarion-usa.com/RunTime/Materials/KnowledgePoolFiles/C3_Radio_Signal_Propagation.pdf
etc. for more info
You are on the right track! However, you will need a gain standard antenna, such as a horn antenna.
http://www.ieee.org
or in technical or university libraries.
mi spun off from Scientific Atlanta some time back.
It is the antenna test and instrumentation group.
They used to have a DOS disk of antenna test standard formulas to help you with your space loss, antenna spacing, and the rest. One thing you have to do is make sure your
'range' is clean of reflections.
2) At 2.4 GHz, you don't need to worry about Far-Field. You really need to worry about positioning accuracy & mount stability. If the antenna is not centered your data will be offset, and require manipulation. Even a 20 mm mistake at 2.4 GHz will cause problems.
3) Full 2 port Using the Analyzer's Calibration kit
4) There are several methods in which this can be done. This method is the simplest:
a) Do a gain pattern measurement (i.e. plot in dB)
b) Normalize the result (i.e. 0 dB is the highest value)
c) Substitute the reference antenna for the AUT, make a gain measurement.
d) Add gain from "c" and reference antenna factor (dBi) to change the plot from dB to dBi. The plot can also be done in dBd (depends on the industry you are in as to which is preferred).
5) Since you will be measuring the gain, the absolute transmit level doesn’t make too much difference. However, keep these three criteria in mind
a) Maintain a low enough signal that will keep the analyzer's receiver from overloading
b) Maintain a high enough signal that will allow sufficient power to differentiate features of the plot from noise, i.e. closely spaced nulls
c) Take enough samples to ensure that analyzer noise is averaged out of from the plot.
The other replies also apply. Attempting this measurement outdoors requires careful consideration of reflections and ambient signals. Since the free space loss at 2.4Ghz is relatively large, you can ignore all objects > 4m away (assuming that the dynamic range of the analyzer is 80-100 db). Don't forget about the ground plane. You should consider using absorbers on the ground plane, or elevating your test setup.
Reference antenna is a good idea to calibrate all measurement equipements. Normally horn antennas are used as source antennas and for calibration (ref. antenna). They have good directivity.
2. At those frequencies You don't have to worry about far field. You won't measure at 3 cm distance. 2m is OK. I have maesured my antennas ( 12GHz ) with about 2.5m. I had enough good results.
3. To measure output of Your AUT You can use network analyzer as power meter. That is the parameter that You need to plot characteristics. It doesn't matter if You choose 1 or 2 port calibration since You are using just one port.
Input matching of Your AUT You can measure in normal way as normal s-parameters.
4.To achieve dBi You would need extra measurement with reference antenna to calculate results then.
5. Illumination power should be enough to achieve enough dynamic. Your measurements should be visible over noise. I don't know what type of antenna You are using but even when You use 1Watt You don't have to worry. (anechoic chamber)
Good luck,
buding.
Also, you can move one side of your setup back and forth (closer & farther apart) and watch the network analyzer for reflections interacting with the measurement. The signal level should change only by the delta in space loss. If there are quick ripples then you have a reflection problem.
You should always know the "general" pattern of what you are measuring to get a feel for the measured data to determine if it's real data or in error (i.e. know the pattern of the gain horn you are using)
The IEEE book is a great reference.
Good Luck
photistor@hotmail.com
3) Use a Full 2 Port calibration when you want both Transmitted & Reflected vector measurments(Magnitude & Phase)- For either the combination S11, S12 or S21, S22; which combination you chose depneds on your equipment setup.
Antenna engineers want both Trasmitted and Reflected data to improve their design. With only one side, something important can be overlooked.
Special notes:
A Horn antenna makes a good opposing antenna(source or receive) becuase of it's direction properties. But any highly directional antenna will work.
The other item that might be of importance is polarization. Physical polarization is time consuming & error prone(especially when trying to account for phase).
When you need H & V data, use a switched phase antenna with a high cross-polarization factor. (Dual polarized Horn or Pi-Plate). If you don't need H & V, use a circular polarized antenna.
