Allowable Bearting Capacity vs Soil Modulus
Excuse this basic question from a humble mechanical engineer.
I am interested in the design of buried flexible pipelines. The geotech reports I receive refer to allowable bearing capacity in kPa. How can I relatye that to the soil modulus in order to use the Spangler equation to design trench and pipe for a gravity main.
Are there classic papers or books, perhaps even software, that can allow me to interpret the data to enable the calculations to be performed.
RE: Allowable Bearting Capacity vs Soil Modulus
As far as relating bearing capacity to soil modulus, one needs to know the amount of settlement which will be caused by the applied contact pressure. Soil modulus is based on soil response (ie. the amount of settlement for a given load).
Let me know if your geotech could use the paper
Paper could be emailed to geoff.stone@lendlease.com.au or faxed to 61 2 8850 2324.
Geoff Stone
I too would like a copy of the paper you mentioned. Please send via e-mail to jheidt2543@aol.com. Thanks in advance.
Gibbycu is right - you will need a geotechnical engineer to assist you. There is no direct correlation between modulus (stiffness) and bearing capacity ("yield strength") for soils; nor is there one for steel, aluminum, copper, etc.
How big is your pipeline? What materials are used?
If you already have an allowable bearing pressure given in a geotech report, usually the modulus of subgrade reaction can be estimated from the allowable bearing pressure by the following relationship:
Ks = 36 x qall
where:
Ks = modulus of subgrade reaction in kips/ft^3
qall = allowable soil bearing pressure in kips/ft^2
in SI units the same equation will be:
Ks = 120 x qall
where:
Ks = modulus of subgrade reaction in kN/m^3
qall = allowable bearing pressure in kPa
these equations consider a factor of safety of 3 and a maximum settlement of 1 inch, which is typical by geotech eng in providing a qall. reference to this relationship can be found in Foundation Analysis and Design (5th ed.) by Joseph E. Bowles, 1996. McGraw-Hill, page .
Also this is referenced in the U.S. Army Technical Manual TM 5-818-1 Soils and Geology Procedures for Foundation Design and Other Structures (Except Hydraulic Structures)page 10-5. This manual can be downloaded from:
http://www.usace.army.mil/inet/usace-docs/armytm/tm5-818-1/
Hope this gives a quick check for your findings.
CIS Geotechnical
jrodriguez@centralindustrialpr.com
Às other members in this forum.... I too would like a copy of the paper you mentioned. Please send via e-mail to jrodriguez@centralindustrialpr.com.
Sorry for bothering, but this forum is the best I have found for sharing information that is out of print or difficult to find.
Thanks in advance.
CIS Geotechnical
John
Don't use equations you don't understand -
i too would like a copy of the paper you mentioned. apprecaite if you could e-mail a copy to
wong_kt@wohhup.com
Thanks in advance.
regards,
