Pavement reclamation using liquid calcium chloride
I have a heavily deteriorated parking lot and, as part of the repaving process, am considering reclaiming the pavement. The contractor has proposed adding liquid calcium chloride in the reclamation process (cold-milling to a depth of 4-5"). I have experience with cold-milled reclamation and soil-cement subbases, but not liquid calcium chloride. A few questions arise:
- How much strength can I expect from the new subbase? Is there a "___ inches of liquid calcium chloride stabilized base = __ inches of asphalt" comparison?
- The majority of the lot is used for car/light vehicle traffic; some areas are used for truck traffic.
- It is envisioned to apply the asphalt pavement directly on top of the reclaimed material. Will a tack coat be required?
- A new concrete pad has been installed adjacent to the area being paved and I am concerned about the impacts of the calcium chloride in the subbase on the new cocrete. How far apart should the two materials be kept?
- Any other issues I should be considering?
Thank you for your help,
Don
Don
RE: Pavement reclamation using liquid calcium chloride
