Circular rod with square bore
As part of a shaft design I am working on, there are a few shaft collars that have a square bore to fit on a square shaft. I was wondering if these types of collars/sleeves are relatively common and could be found from a supplier. I have seen these very commonly in the past and it doesn't seem like these are just machined at a low production level.
RE: Circular rod with square bore
http://www.staffordmfg.com/Search.aspx?famName=Squ...
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
...if so, go to...
https://sdp-si.com/web/html/shaftacc.htm
...and check out the items labeled 'Sleeves, Square Holes'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
You really can fit a square hole into a round peg.
(sorry, couldn't help it)
STF
