Update EDS file(MM200 RELAY) to add input in RSnetworx for devicnet ?
I have a CompactLogix PLC linked by a devinet network with a mm200 relay(GE), the eds file does not contain the input I want to import to my program in RSLogix 5000, does anyone know a method to modify the file eds to get the desired input.
thanks for help.
RE: Update EDS file(MM200 RELAY) to add input in RSnetworx for devicnet ?
A 'standard' EDS file can be edited with notepad.exe as it is a 'standard' ASCII format.
To get the edit correct to do what you want you need to consult the original manufacturer.
