Remove dimension line
it's possible ti remove the dimension line indicated by the image attached ?
Thank you...
Using NX 8 and TC9.1
RE: Remove dimension line
Use the radius rather than radius to center dimension type.
www.nxjournaling.com
Has this drawing been translated from I-deas to NX using CMM?
Then I need to delete them and create again ?
Interesting.
Anyway...thank you a lot.
P.S.This drawing is native NX.
Thank you...
The original dimension 'type' was inappropriate. You have no choice but to delete it and create a new, PROPER dimension.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
