Vacuum Infusion
Vacuum Infusion
Vacuum Infusion
Noob to the forums and to vacuum infusion. I have recently started in on doing some carbon fiber with the lay up technique and need to venture into vacuum infusion.
Other than the CF what other materials and what layered order do I lay them?
Bottom to top -
1. Carbon fiber
2. Peel ply?
3. Flow media mesh?
4. vacuum bag
Sure there is something missing.
RE: Vacuum Infusion
Wow a week and no reply. I guess these forums are dead as I highly doubt this is a difficult question. Oh well. Thanks anyways
RE: Vacuum Infusion
Your question is way too broad. The forum is for engineering tips not how-to manuals. If you get one of 100 details wrong, your infusion will fail.
RE: Vacuum Infusion
Well if it was to broad then a friendly reply asking for more info or such would have been helpful at least. Its cool. No worries.
RE: Vacuum Infusion
Use glass fiber cloth until your process is worked out; no sense making garbaage with carbon.
Crank up your Google.
You can actually learn a lot from five million stories about making cold air induction tubes.
Mike Halloran
Pembroke Pines, FL, USA
RE: Vacuum Infusion
The resin
RE: Vacuum Infusion
google it. the rough procedure should be out there.
