density of petroleum products
I am looking for an algorythm or an equation which i can use to convert density of petroleum products from physical temperature to 15oC.
Any help will be most welcome
RE: density of petroleum products
You can visit the site http://www.viscoanalyser.com/page8.html. This is, in my opinion, a good place for you to start. This site is recommended by a reputed member of this Forum jmw.
El que no puede andar, se sienta.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
There are waxy fractions solid at ambient temperatures. Nevertheless, have a look at thread491-82117: Generalized products density correction algorythms?? and thread481-97175: Diesel - Volumetric - Temperature differences for more comments.
