how to delete an existing pattern in sketch in nx 7.5
I'm looking for a solution how to delete an existing pattern in nx 7.5 sketch.
I have pattern a rather complex sketch, the instance are connected to the orginal, I don't want to lose.
I can active the pattern, but I cannot delete it like a feature, what is the workflow to do this?
sorry new in NX
regards
Erwin
RE: how to delete an existing pattern in sketch in nx 7.5
The pattern feature doesn't appear but you just have to delete the Pattern Constraint, then you can delete or not the remain cruves. Have a look at the attached jpeg file
I hope this help
Didier Psaltopoulos
http://www.psi-cad.com
yes and no, on none complex sketches it will work...
I my situation the patterned curves interfer, and after deleting the pattern constraint the lines still exit as orphans,
I'd like to delete the pattern like feature. ...Even changing from circular to linear is not supported.
sorry new in NX
regards
Erwin
In NX 8.5 by Just double click on the constraint symbol you can change the Pattern type.
I am not sure about NX 7.5.
Mathi K
@Erwin: You must ask for an Enhancement Request
@Mathi: I confirm that editing pattern work also in NX7.5
Didier Psaltopoulos
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Good Idea
Didier Psaltopoulos
