user_defined_view_names_similar_look_NX 8.5.1.3
I want to keep the same name 'both in the sheet view and also in the Navigator tree'.
Is it possible?How we can get this?
Mathi K
RE: user_defined_view_names_similar_look_NX 8.5.1.3
Hi Mathi,
How did you rename the view ? because :
If I use view/properties to change the name I have the same name in both location
and
If I place a specific saved view in modeling I have the same name with a suffix (@ and a number)
Which NX version are you using ? (I have tested in NX6 to Nx8.5)
Didier Psaltopoulos
http://www.psi-cad.com
Hello Didier Psaltopoulos,
Thanks.Your solution works.
Earlier I tried by double click and use the Customized name option.So it did not work.
Mathi K.
Hi Mathi,
I don't understanf the way you have tried to change the name (double click and use the Customized name option). Could you send a screeshot ? and give the NX version
Didier Psaltopoulos
