Load on Top Half of Beam Only
I have a plan check comment to check torsion on the upper half of a steel beam (I'm using an HSS section). Is there a way to model a load that acts uniformly across only a section of the beam? See attached PDF.
RE: Load on Top Half of Beam Only
