piezoactuators and amplifier?
Hi guys
I want to buy some piezoactuators and amplifiers, does somebody happen to know which company is better in these products? thanks!
RE: piezoactuators and amplifier?
first of all you should clear about the fuction you are going to do with the pieazo actuator.
there are plenty of actuators available in the market.
right actuator at right place will do more efficient work.
if you want to know more about u just let me know.
you can get deails from www.PI.com,www.piceramics.com
www.cedrat.com
cheers
P.Murali
Cameron Anderson
Sales & Applications Engineer
Aerotech, Inc
St. Paul, MN
www.aerotech.com
"Dedicated to the Science of Motion"
The stopping power is good enough that there are manufacturers designing the motors to be used as brakes for aircraft landing gear. The wheels are spun up prior to touchdown to reduce the friction wear on the tires and after touchdown, the motor behaves like a disk brake.
TTFN
