Topping hob allowance
can anyone tell me what is minimu and maximum topping hob allownace for worm wheel manufacturng. I am using 0.5-0.6mm, but I wander if I can use 0.2-2mm. What would be the result of doing that? Cycle time only? feaibility of the hob to do so?
RE: Topping hob allowance
I don't understand what you mean with these questions;
"Cycle time only?"
"feaibility of the hob to do so?"
Ron Volmershausen
Brunkerville Engineering
Newcastle Australia
http://www.aussieweb.com.au/email.aspx?id=1194181
would make more sense.
-machine blank first. It has the same OD as finished worm wheel, but throat diamtere is increased for "topping hob allowance" 0.5-0.6mm, which is neded in order to achieve throat diameter concetricity.
- Topping hob will cut throat diametter to size as finished gear specification and cut teeth flanks.
I want to unify some blanks for diferent gear sets ratios. To achieve that I need to increase or decrese this "topping hob" allowance. So the question is how much I could increase or decrease from 0.5-0.6. Is the consequence cutting cycle time only (longer or shorter cutting operation), or topping hob has some limitations.
Thanks in advance.
due to the lack of answers it seems to me your question is still confusing.
what are to trying to do. I normally finish the OD prior to hobbing & tolerate a little runout.
I generally do not use a topping hob. but most of the parts I produce are short runs.
I would take a shot in the dark to say .5 mm is to much. more like .25 mm.is more resonable.
I would suggest not relying on our suggestions & do an actual experiment or test. run a partial group of parts.
& do a test run.
Do you have a Blue Print?
Mfgenggear
if it can be built it can be calculated.
if it can be calculated it can be built.
