SSC requirement
SSC requirement
SSC requirement
hi
For forged Stainless steel fittings and flanges which meet NACE MR175 requirements, is SSC test mandatory for these material? if yes or no, please specify the clause of the standard.
RE: SSC requirement
Why not read through the standard and conclude for yourself? When you say 'meets NACE MR(0)175 requirements,' do you mean that you have also confirmed the environment to which the material will be exposed to and found it acceptable?
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
RE: SSC requirement
What type of stainless steel, i.e. austenitic, martensitic, etc.?
