ASME UG-34 vs. Taylor Forge Bulletin Bulletin 45
I am currently analyzing a bolted flat head that uses a full face gasket. Using the formulas in UG-34 I get a higher required thickness than what is calculated by PVElite. As it is a full face gasket, the PVElite output calls out that it will be designed per Taylor Forge Bulletin NO. 45. The difference in the calculations is that PVElite uses the gasket reaction diameter (G) in the thickness calculation, whereas fig. UG-34 (p) indicates that the bolt circle diameter should be used.
I assume in this situation the more applicable value to use is the value calculated using the bolt circle diameter since it is a clear requirement in the code (and clearly more conservative). Can anyone provide some guidance with this situation?
RE: ASME UG-34 vs. Taylor Forge Bulletin Bulletin 45
You can also run it from the shells module as a flat head, you have to input the proper attachment factor and dimensions.
Also, what version of PVE are you using? I have found 2013 uacceptably buggy and am not using it.
Mike
I'm using PVE 2013, and have noticed some bugs as well. Whenever something doesn't seem right I run it through 2012 to verify. I'll run this flange through 2012 tomorrow to check conformity.
Thanks for the input SnTMan.
