Required sized of steel coupon taken from existing beam or column?
Is there a standard size in taking steel coupons from existing steel members for purposes of determining the tensile strength?
RE: Required sized of steel coupon taken from existing beam or column?
I have typically used in the past, 12" long by 2" wide if possible. If not, 8" long x 1-1/2" wide. Either will allow preparation for a reduced section tensile test where the gauge length will be at least 2". Check ASTM A8 for specifics of coupon testing.
I didn't realize the length dimension would need to be that large. Can you get by with less?
I'll try to round up a copy of ASTM A8.
Looks like it must actually be E8, not A8.
Or maybe A370?
abp...my apologies...it is E8
