STL 21 & STL 6
STL 21 & STL 6
STL 21 & STL 6
Can any one advise me if STL 21 is better than STL 6. This is for trim for gate valve
RE: STL 21 & STL 6
Stellite 21 is quite rare, and Stellite 6 quite common, but it all depends on your application. What are your process conditions? Depending on that, you might opt for Stellite 6, 21 or another trim/overlay/treatment altogether.
Corrosion resistant, exotic alloy valves from The Alloy Valve Stockist in Barcelona, Spain http://valvestockist.com
