what are the recommended speeds for drilling GLARE
Hi all,
what are the recommended drilling parameters ( cutting speed and feed rates ) for drilling GLARE material.
can I use similar drilling parameters used for Al2024 , any suggestions ?
RE: what are the recommended speeds for drilling GLARE
Try cutting some samples before you go into production if possible.
Bill
thanks for the reply, I am doing a research and I want to cover as much as possible of the drilling parameters but I don't want to use any random cutting speeds and feed rates , I prefer to have a more realistic combinations of cutting speeds and feeds.
B.E.
You are judged not by what you know, but by what you can do.
