panel on front of building - wind loads?
See the attachment below - that's a random example I picked from google images.
It's a HDG frame with a commercial banner in, mounted on the front of a building.
Non-seismic zone.
Apart from it's own weight, what else is there? Only wind? I'll also take the weight of two guys hanging from it, as the bottom bar can be reached without a ladder.
How do I get the wind loading (I guess negative pressure will be present) ?
Any other pointers, I suppose someone has done this before?
Thanks in advance.
Non-seismic zone.
Thanks in advance.
RE: panel on front of building - wind loads?
And for your shear, use someone hanging on it as you have suggested.
Mike McCann
MMC Engineering
No other loads (seismic, vibrations, etc.) present. Seismic won't govern unless the thing is really heavy, which it's not.
I was indeed talking about the attachment loads.
@ hetgen, I do not understand what you are saying - do you mean that the rubber ropes pull on the frame (like an inward pressure)?
If so, OK. When looking at it as a uniform divided pressure, it's low enough that it can be neglected. If that's not what you mean, can you please explain?
