plasma coating
plasma coating
Does anyone know of a company which can plasma coat inside a two inch ID pipe as they do in turbine coating. The pipe is approx 54 inches long, hastalloy X material and will be heated up to 1700 C I am currently using extruded alumina tube but it is very fragile. I would like to switch to a high temp alloy. possible? The pipe needs to be 100% protected against corrosion inside. Diffusion alluminide bond coat, outer coating partially stabilized zirconia?
Conmments please
Thanks guys and gals
Conmments please
RE: plasma coating
RE: plasma coating
After removing from the oven and taking out of the vessel the part is re-heat treated at 1250°C. That is a diffusion heat treatment and that’s it. I am sure that the coating withstands 1500°C but possibly it can be used beyond and above.
There is also a more sophisticated process-coating used for combustion chamber protection SermaLoy J. It is a patent of Sermatech Inc so you can try them too.
