Piper PA-28R-200 Arrow manifold pressure gauge fluctuation
Fluctuating manifold pressure gauge on a Piper PA-28R-200 Arrow. It's probably the gauge itself at fault but whilst checking for leaks/blockages, I found a small hole drilled in the bottom of the manifold pressure pipe coming out of cylinder 3. Is it supposed to be there, maybe for drainage or dampening pulses?
RE: Piper PA-28R-200 Arrow manifold pressure gauge fluctuation
Suggest You put a piece of aluminum foil tape over the hole and see what happens! IF your MAP settles-down, then You will have a pretty clear clue-card that the hole should NOT be there. IF it does NOT settle down then the hole is probably NOT an issue.
Regardless, contact Lycombing or Piper service center with this issue for formal clarification/repair/etc.
NOTE.
IF there had been small holes in each of the MAP pipe for each of the cylinders, I might tend to say, "it was meant to be". However, only (1) hole on one cylinder is likley an abberation.
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
Unfortunately, in science what You 'believe' is irrelevant – "Orion"
