plasma coating
plasma coating
Does anyone know of a company which can plasma coat inside a two inch ID pipe as they do in turbine coating. The pipe is approx 54 inches long, hastalloy X material and will be heated up to 1700 C I am currently using extruded alumina but it is very fragile. The pipe needs to be 100% protected against corrosion inside.
