Tensile Strength - ASME Section IX & AWS B4.0
Will the tensile strength of weld specimens(pipe) when machined to and tested in accordance with both AWS B4.0 and ASME Section IX vary significantly ? Will the maximum load be affected by the size of the reduce area for both AWS B4.0 and ASME Section IX (pipe) during the tensile test?
RE: Tensile Strength - ASME Section IX & AWS B4.0
The ultimate tensile strength shouldn't vary by a significant amount. The load required to pull to failure(max load)will increase proportional to the cross sectional area increase of an AWS B4.0 specimen.
