GSD - Intersection multi result to be as shown as individual entities
Hi Guys,
Could somebody help me on this.
I working on to create a line or point (intersection result) between two surfaces and curves.
If both intersects at one place then there is no issue, but if they intersect at more than one location then
i need the result to be created one after other in tree. Like if the intersection results in 6 lines or points then
in tree i need lines or points one by one in serial arrangement.
Point1, point2, point3, point4, point5, point6 or Line1, line2, line3, line4, line5, line6
by deafault it creates all of them as single entity.
Maddy
Maddy
Maddy
RE: GSD - Intersection multi result to be as shown as individual entities
Surface intersection.....
Maddy
Can you use Disassemble command on Intersection element ?
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
and these points will not be associative with parent curves at all.
but the points is if the curve shape changes then these points has
to get adjusted themselves.
Maddy
Fernando
Maddy
Anything on getting the result through automation on this..?
Maddy
Try to repeat intersect command for 6 times. Each time select "keep only one subelement using Near" and select a vertex of one of the intesecting element. you will get all 6 interesects as separate Near features but with the link established to the intersect. But be careful, if the intersect fails in next update due to modifications, the Near feature will get modify or fail as it may not be able to find the intersect. Hope it helps you.
Thanks for reply,
Ya that's what I've been trying to do through Macro (VBA) and got stuck up in "selecting a vertex of one of the intersecting element".
How to select it through code... as i'm not getting any idea on how to select the vertices one by one once i create the intersect.
Maddy
Sorry Maddy, I really don't have time to look on this problem now, maybe in few days...
Fernando
I apologize for not giving you a straight answer but I hope this will guide you in the right direction.
@ ferdo,
No issue, Thanks you for your time and thought on this, hope to hear something to go ahead..
@supergee
Hi, Thanks for your kind suggestion, yes i do ware about what near is the
proper solution as well as extract, providing the reference to create 1st point as near is OK, but
to create 2nd point as near, i need to pass the 2nd vertex of intersect as reference,
but finding and fetching this point and succeeding ones to pass as reference is where the problem lies.
All i have is a curve and a surface as inputs.
Maddy
