Unable to calculate detailed mass properties NX8
Hi friends
I have some problems with solids in modeling, when I create a solid part and I apply mirror body, I can not calculate mass, volume, weight, surface area with "Analysis>measure bodies", only appears a message "Unable to calculate detailed mass properties" in dialog box and all results are equal zero.
Have Anyone of you ever met these kind of problems Do someone knows the reason and the solution?.
Best regards
Tom
Best regards
Tom
NX 8.0.0.25 64bit Windows 7 Enterprise
RE: Unable to calculate detailed mass properties NX8
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Please check the file attached.
Best regards
Tom
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Let me try with other file, because I cant share the original model (confidential policy).
This mourning I deleted the mirror body and I apply again "mirror boby" & "Analysis>measure bodies", and it worked well.
Tom
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
www.nxjournaling.com
I checked "examine geometry" and it made me a "tip", I deleted the last operations from the part navigator until find the mistake. the problem was in a blend, I don´t understand why the blend was the problem but when I tested again with this blend, the problem occurs.
Thanks for your patience
Best regards
Tom
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
